It would be great to get peoples thoughts on the best way to easily and quickly manage (administrate) access to Jira and Confluence for external users
some context...
We have a number of 'external partners' that we collaborate with 'to varying degrees'
We want to be able to shared Jira 'issues' and Confluence 'pages' without having to move or copy them to dedicated (siloed) Jira Projects or Confluence Spaces
We simply want to be able to allow an External Partner User or Group access to specified Issues or Pages within a Project or Space, but limit access to that particular Issue or Page and their Child Issues / Pages
Currently we have to set up dedicated Projects and Spaces where we either move or copy Issues and Pages (and hence duplicate content)
I understand that Jira and Confluence are 'inclusive' products, but given the move towards collaborating and delivering across companies and organisations, it would be good to enable this without duplicating content
Any thoughts
Cheers
Warde
Thank you, Maykenna!
What is your experience of addressing this question with setting up a separate Jira environment that is designed to be shared with external users? That to mitigate the risk of exposing internal company information.
Separate Jira instances would have to share their data. There are (paid) Jira Apps which can sync between instances. You could spin up some free Jira Cloud instances and most Jira Apps are free for 2-4 weeks. Lots of opportunity to do Proof of Concept work, if you want to explore that direction.
I haven't used those sync apps (yet - there has been some discussion here). I have heard that non-Cloud Jira instances probably shouldn't sign onto a sync App, as the vendors aren't supporting them (due to the pending sunsetting of some of those non-Cloud platforms).
Jira permission schemes are quite capable of "mitigating the risk of exposing internal company information", as I noted above. The key risk is the human(s) in the loop. To mitigate that, keep the themselves in sync with the admin details on this critical issue. It sounds like that's important to the business, so make it a priority.
I'm Matthias and I'm part of the team behind Backbone Issue Sync, such an issue sync app, @Mykenna Cepek mentioned.
We have several customers using our app to have an internal Server/Data Center instance which is not accessible from the outside world and synchronize parts of it with an externally available instance. This external available instance may be either Server/Data Center or Cloud.
I can definitely say that we are still supporting Server & Data Center customers to synchronize with other Jira instances - no matter what the deployment type is. And I'm pretty sure that this is also true for the other issue sync apps.
If you want to have a more detailed perspective on such a scenario, you can also check out this blog post on our homepage or contact us via help@k15t.com to discuss your specific use case.
Thank you @Mykenna Cepek and @Christian Gaiser for the feedback! I really appreciate it! I have tested Backbone Issue Sync in Jira Cloud instances (have made just some basic tests to sync projects between two jira cloud instances) and yes, it is an option I am considering if we decide to go this way. Good to know who I can reach out to if this alternative becomes relevant. Thank you! 🙏
It's good to hear, @Matthias Gaiser _K15t_, that your sync app is continuing to pay attention to the Jira Server and Data Center markets.
My information came from both our own internal testing, and also from a large client who did their own substantial testing of several sync solutions, and ended up unsatisfied, creating instead their own solution using scripts and APIs.
I would still recommend Proof-of-Concept efforts to anyone, to ensure that a solution addresses all of your requirements and needs.
I totally agree doing your own proof-of-concept is key in order to get a solution that fits your needs.
If there's anything missing when you do a POC and our solution doesn't match your needs, you can always get in contact with us. I can't promise we'll add your feature, but I can promise that we're listening.
(Francis here - with the Exalate team - another issue sync app)
FYI
We are continuing supporting our apps way beyond the EOL of the underlying application.. For instance - our apps are still supporting Jira 6.3. Although that Atlassian stopped to support this version long time ago, there are still customers actively using this environment.
Regarding the use case - there are a couple of our customers that have one central Jira (on cloud - used by the customer team). For each of their partners (customers/suppliers) they did setup a Jira cloud instance - dedicated to one partner.
That way they avoid that information leaks between the customers themselves.
It is a more cumbersome setup - but it addresses a major concern.
More information can be found here
You can also look at setting up a Security Issue Scheme. This worked for us on our HR Project we had.
We created custom groups, in user administration, then added those groups to projecs assinged to role of Users. All our internal users are also in a group, so each project will have at least our internal users group, and if accessed by an external group that will also be assigned with the same role of Users. We are not allowing external users access to Confluence, but this is working for us for Jira.
I did something similar.
1) I created an 'external' contractor group. Users added to that group don't get any of the usual default product access permissions.
2) For projects that have contractors, a project admin just adds them to the "contractor" role.
3) I created a specific permission scheme for the projects that I know will have contractors. I gave the contractor role the minimal permissions needed.
This works for us.
Before doing the above, I had a separate Jira instance for contractors and that was a big pain because we kept having to duplicate tickets.
Hi @Ken Siskind
Thank you for sharing! Really appreciated! May I bother you some questions around the concerns I have using this approach?
Thank you!
We have about 140 Jira projects of which 100 are customer projects, which the relevant customers have access to so we did the following:
To answer your questions:
1) For external users, we just manually invite them through Jira. Internal users are handled through Atlassian access
2) External users can only see a project when they are added to a role on an individual project. If they don't have the role on a project, then they have no access to that project
3) they can see a list of dashboards, but since they don't have browse access to projects they can't drill into any of them. You got me nervous about this one, so I just re-validated that this was the case.
We also found a few other points of exposure, despite this type of "external user lockdown" via Jira Permission Scheme:
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
