×I am involved in multiple projects as a Scrum Master, Project Manager, Program Manager. Some projects are Scrum and some are Waterfall (business projects).
There are tasks that I'm either responsible for or want to make sure are getting done. Some examples:
I want a way to track all of my work within JIRA. I believe in working out of 1 system.
So I have 3 areas that I need to handle and want to run by you:
Then I can create a board and dashboard that pulls all of this in so I can keep track of what I need to do across everything.
Hello again Marc,
Apologies that it took awhile, though over a past few days me and Dastin didn't have a chance to sit together to go through your ideas together.
Here's how we see it:
Some examples:
As far as we are concerned, this can be achieved only in Confluence by adding a new Page Template – Retrospective. Since Jira is a Project Tracker (and so is BP and BG), this cannot be applied to the environment’s rules. As we understand your concept, the idea behind it is to create a reoccurring task which would reflect the nature of a proces (not a project).
More information on Sprint Reports, Creating Confluence Pages and Creating Retrospective Blueprints can be found in linked Atlassian Confluence Documentation Articles (sadly we were not able to link them here).
We would recommend creating ‘Team’ Custom Field in Jira. This recommendation is based on experience brought by majority of SoftwarePlant’s customers. From their perspective using such ‘Custom Field’ to track which team executes which task within project gives a great value and complete insight into the workflow. Such an approach if generally perceived as most efficient.
[ Good for reporting, creating dynamic queues for team’s workflow etc.]
This description perfectly fits BigPicture’s Roadmap module description. In our Roadmap sprints can be synchronized with BP’s Cadences (small team mode). After such synchronization, all task dependencies are visualized on the Roadmap as cross-team dependencies
This is the core idea behind BigPicture's concept of a Program.
The first thing that comes to our mind would be to create an ‘Artificial Task Template’, meaning to create a Program in BigPicture with Artificial Tasks that would rather describe project’s structure than the scope.
Once you know what the structure should look like, you may nest it with Artificial Tasks in your Program and create a tamplete which with one button will load them in desired sequence. Of course, there are few alternatives to this approach though we found this one to be the easiest and most efficient in Waterfall model, which can be achieved at this time.
As you've noticed, in some cases you might need to use Confluence.
To be frank, we find it hard to imagine what you would like to achieve in this case.
This Is an amazing idea because your Personal ’Jira Task List’ project can be included in the scope of your business Programs.
Good approach, as when your admin stories are assigned to sprints, they can be a good reference while creating a Gantt chart.
Sometimes such an approach is desired and can be found beneficial, though please bear in mind that when your tasks are in Backlog, they are not included in the sprint report. What would be convenient in your case?
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
