I need to create tasks and subtasks of these tasks by using automation when the user creates epic.
I was able to create tasks in epic, but I don't know how to create subtasks in these tasks.
Any help?
Solved! Go to Solution.
Thanx for quick response @Sergei Gridnevskii
But how do I distinguish in the second rule whether the task that was created was created by automation or by the user?
Well the easiest way - by comparing the Summary of the ticket with a predefined string. This of course make it possible that someone uses this string and triggers your rule - but you may be creative, e.g. by using something like
[Autotask785] Check server logs
and then search for [Autotask785] in Summary
If you do not like it - create a custom field like a checkbox "Automation" and fill it when you create tasks. In second rule check if it is empty and continue if not.
You can also use a different field for that.
Labels for example or even a custom field.
I like the idea of triggering another rule for subtasks creation.
I managed to do it by one rule only, so it is triggered by itself.
Hello Martin,
My approch on your problem would be to create a second automation that triggers on the creation of a task and make sub-task here.
Have a good day.
Hi, Martin.
You can accomplish the creation of tasks and sub-tasks to a single epic in a single automation rule by using the branch component "For Most recently created issue.
Make sure to set the field "Epic Link" for tasks to the parent Epic. Sub-tasks are linked to tasks only, not to epics.
Here is a visual representation of an actual rule that creates tasks and subtasks to a newly created epic:
What if he is in a big organization and someone creates another issue at exactly same time?
Good point. I would try with "For Current issue" instead of "Most recently created issue".
how will it look (I mean those branches), when I need to create more than one task in epic?
The rule structure I use is the following:
1. If it is an epic,
2. then create task 1 and edit field Epic Link to "Copy from Current issue",
2.1. then branch on task 1 - create sub-task 1a, sub-task 1b, etc.
3. Then create task 2 and edit field Epic Link to "Copy from Current issue",
3.1. then branch on task 2 - create sub-task 2a, sub-task 2b, etc.
Here is an example of points 3 and 3.1:
You see it becomes more and more complex and I hate rules that do not fit on one screen.
Splitting rule to several rules makes it much more easier to support. And I think atlassian loves it because it has to run a rule on one server while it can run 10 rules on 10 different servers in cloud and finish the whole task 10 times faster.
your idea worked for me, but only when I used "Most recently created issue" for branches.
When I used "Current issue", the subtasks were created under epic and not under tasks created in epic.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
