Is it possible to move the linked issues section to the top of the issue detail view?
melina_scholl
Hi Jira community,
I am wondering if I can move the linked issues section to the top of the issue's detail view. When the linked issues are on the bottom, I think they will be forgotten as you can not directly see them. It would be nice to have them on top so that people really use them and directly see to which other issues this issue relates to.
Melina
3 votes
Gerald Bihr
November 15, 2021
Hi @melina_scholl
As far as I know, you can only control the order for the create issue view by ordering the fields in the related screen configuration.
But in the edit or issue detail view, the Linked issues section as a fixed place on the screen.
Marc - Devoteam
November 15, 2021
@melina_scholl
@Gerald Bihr is correct. On the view/edit screen the Linked Issues section is in a fixed location. This is not adjustable.
Cheers.
Srujan kumar
setting up fields @ screen level can make it done.
melina_scholl
Thanks everyone for your quick answers!
@Srujan kumar what do you mean by that?
Marc - Devoteam
November 16, 2021
Hi @melina_scholl
This answer is referring to the create screen as explained by @Gerald Bihr
