SLA updates using automation
Clare Lawson
December 4, 2023
Hello!
I have a Service Project that I need to get some automation around.  Basically I want a report or a filter to run each day that shows when a ticket is out of SLA.
In this case, the SLA is that our team has to touch a ticket within one business day.  If not, we would like an alert to trigger.
Can someone help me understand the best way to do this?
In addition, we would like an automation that tells us if a ticket has not been updated in 48 hours.
Thank you so much for all the help you all give!!
3 comments
Carlos Faddul
December 4, 2023 edited
Hi @Clare Lawson , why you don't use a Filter Subscription in Jira ?
Maybe this will serve you better than triggering an automation daily
Derek F_ December 5, 2023
I think this is the right answer. Something like
resolution = Unresolved AND "Time to first response" = running() AND "Time to first response" = breached()
lisa_simpkins
@Clare Lawson
I have automation setup to notify the assignee when the Time-to-Resolve SLA will breach within 1 day if not addressed.  I've included the contents below, which you can modify to fit your needs, of course.  Hopefully, this will help get you started.
When:  SLA = Time to Resolve
Trigger when SLA has:  will breach in the next 1 Day
Then:  Send email
Subject:  TTR SLA for {{issue.organizations.name}} {{issue.key}} Will Breach in 1 Day
Email Content:
Assignee: {{assignee.displayName}}
Link: [your.instance]/browse/{{issue.key}}
Summary: {{issue.summary}}
Reporter: {{reporter.displayName}}
Status: {{issue.status.name}}
Please:
1. review the ticket to see exactly when the SLA will breach if no action is taken;
2. confirm the ticket is in the correct status (which can impact SLA clock); and/or
3. add an update to the customer or an internal comment, depending on the circumstances.
Internal wiki:  [link to our internal knowledge base article]
Mario GELES
December 5, 2023 edited
Hi @Clare Lawson
For your automation that tell you if a ticket has not been updated in 48 hours, here what you can do :
When : Planification every 1 day at (set the time you want to receive the email) + JQL search with a JQL query like that Assignee != EMPTY AND Updated <= -2d AND Resolution = Unresolved
Then : Send an email
For the content of the email you can use the same smartvalues that @lisa_simpkins gave you
