×Actually I tried to create new issue filter in Jira by aligning columns as per the requirement of new issue filter. But, it affects the column aligment on existed issue filter ( so the existed filter's column alignment is also changed by creating new issue filter with new column alignment)
Hi @Jayachandran Chandran first create a filter and save the filter, then open the same filter which you created and select column by using the Filter tab in column, it will not effect other filter columns.
This issue is already fixed by communtiy :-
https://community.atlassian.com/t5/Jira-questions/Favorite-filters-not-saving-columns/qaq-p/232603
https://support.atlassian.com/jira-core-cloud/docs/save-your-search-as-a-filter/
