×Note: If you have been blocked from accessing your Jira Product Discovery project, just follow these steps to restore access instantly. You need to be a site admin:
The time for the next Jira Product Discovery (JPD) phase has arrived! All our Beta customers can now move to the Free or Standard plan. We are grateful for all the feedback you've provided during our beta period, which has helped us shape the product into what it is today.
We've prepared detailed steps for you to complete the transition. Rest assured, your data will not be affected as part of this transition, and you won't be charged unless you've completed the move to the Standard plan.
During Beta, the Jira Product Discovery did not enforce product access checks: this meant that a user with product access to any Jira product also had access to JPD. In the Free and Standard plans, product access checks are enforced: this means that a user can only be a creator if they have JPD product access.
Now, Jira Product Discover has Free and Standard pricing plans where:
In the Free plan, you can have up to 3 free creators and unlimited contributors.
In the Standard plan, you have unlimited creators and contributors:
Creators are charged $10 per month, with volume discounts - the more creators you have, the less you pay per creator.
If you wish to be on an annual subscription, please reach out to your enterprise advocate or contact us here.
Contributors are free.
More details on pricing are here.
Note: Users in Jira Product Discovery can access JPD projects without product access (a license). Users can have different project roles—a creator role requires product access, and a contributor role does not require product access. This is great for people you want to contribute without edit permissions.
You need to be a Jira site administrator to perform most of the described actions.
You need to understand the difference between the creator and contributor roles.
The creator and contributor roles in Jira Product Discovery determine which features are available to each role.
Creator |
Contributor |
Creator is a licensed user with product access to Jira Product Discovery. Can use all available features of Jira Product Discovery
Contributor is an unlicensed user who doesn't require product access to Jira Product Discovery. Can, based on what creators make available
Cannot
Watch a video about creators and contributors.
The first step is to make sure that the contributors group is enabled.
Steps
On the upper right of the navigation bar, select ⚙️ > Products, and then on the left sidebar, select Access under Jira Product Discovery.
Enable the contributors group so the users can access Jira Product Discovery projects as contributors. You can also select an existing group to be JPD contributors here.
Only site admins can manage who is in the contributors group. Members of this group will be able to access Jira Product Discovery projects that have been shared with them. Do not add product access to JPD to this group, otherwise every user in this group will consume a license. This is a special group that JPD knows to read from to get the list of contributors.
Watch a video how to create the contributors group.
Who can be a contributor?
To make sure that users are contributors, the site admin should check one of the following criteria:
Whether the user has product access to a Jira product:
On the upper right of the navigation bar, select ⚙️ > User Management > Directory.
Find the needed user, and then select the name. They are a contributor by default if they have product access to Jira Software, Jira Service Management or Jira Work Management.
Whether the user is added as a member of the contributors group:
If the user is not added to the contributors group, select Add to groups, and then add the user to the Jira Product Discovery contributors group: jira-product-discovery-contributors-xxx.
Site admins should verify whether the creator roles are set correctly. Creators are paid users who get a license and product access to Jira Product Discovery.
To manage product access:
Find the needed user, select the name, and then check what products and groups this person has access to.
To provide product access, click Grant access > Jira Product Discovery, and then from the dropdown, select User > Grant access.
Watch a video how to add creators or contributors.
If you began using Jira Product Discovery before July 19, 2023, check whether the site-admins group has been granted automatic product access.
By default, when you add a new product to a site, the site-admins group is given access to that product. It means that every site administrator will have product access to Jira Product Discovery as a creator and consume a license.
To prevent this:
On the left sidebar, select Groups > site-admins group, and then for Jira Product Discovery, select None. This change sometimes takes a few minutes to be applied across the system.
Note: Trusted users (a deprecated user experience) will also consume a license for all products on the site. In this case, the only workaround is to change the user's role to either Basic or Site-admin after removing product access from the site-admins group.
During the Beta, contributors could access all features that are now available only for creators. Once you are done with the previous steps, we recommend project admins test the setup by enforcing product access checks. In this way, you can ensure the product behaves exactly as it will once you transfer to the Free or Standard plan.
Go to Jira Product Discovery project, and then select Project Settings > Access.
Click Beta edition info, and then select Enforce product access checks.
Watch a video how to enforce product access checks.
You can now verify the number of billable users (creators) and upgrade to Jira Product Discovery's Free or Standard plan.
On the upper right of the navigation bar, select ⚙️ > Billing.
For Jira Product Discovery, select Manage > Change plan, and then choose the needed plan.
If the number of users in the "Billing" section in admin.atlassian.com does not match the number of creators you expect to have:
Wait a few minutes for our internal databases to sync.
Check out this video that explains how to check who is getting billed for Jira Product Discovery and common reasons why that number is higher than you expect and how to fix that.
Manage your billing details
When you upgrade to a Standard plan, we start you on a 14-day free trial. However, entering your payment details before the trial ends is very important to continue using Jira Product Discovery without interruptions. Due to our current billing system, you may need to enter your credit card again specifically for Jira Product Discovery. If you wish to be on an annual subscription, please reach out to your enterprise advocate or contact us here.
Here's a post explaining how to verify billing details.
In the Free and Standard plans of Jira Product Discovery, contributors can't create ideas in discovery projects by default. Project admins can manually turn on this feature in each project. Once it’s done, contributors will be able to create ideas in the project but not edit them.
To enable idea creation for contributors:
Open the needed Jira Product Discovery project, and then select Project settings > Features > Create ideas.
Enable Allow contributors to create ideas.
Optionally, customize the creation idea form.
Watch a video how to allow contributors to create ideas.
If you don't upgrade to the Free or Standard plan, you will lose the ability to open Jira Product Discovery projects. However, we will retain your data for 3 months, and if you upgrade to the Free or Standard plan in that time, everything will work as before.
If you have issues upgrading to the Free or Standard plan, please contact Atlassian support and we'll assist you:
Tanguy Crusson
Product @ Atlassian
Atlassian
Nice, France
277 accepted answers
Register Now
102 comments
