×Announcement for customers of the Free plan of JPD
Currently, Jira Product Discovery allows all customers to select the project access level (private, open or limited access)
If your site is on the Free plan, as of November 15th, 2024, everyone with creator product access will be a project admin. It will not be possible to change the access permission scheme.
We're making the following specific changes to the project access level:
Existing projects in sites on the Free plan: Current free site admins won't be able to change the settings after 15th November.
New projects in free sites: the default access level will be set to "open," allowing everyone to access the project.
These changes are intended to align JPD with the rest of Jira, where customers on the Free plan do not have the option to choose a project access level
If you switch from the Standard plan to the Free plan, the project permissions will be locked in their current state. To change them, you will need to upgrade back to the Standard plan.
Our Free plan is for small teams of fewer than 3 creators who may be just getting started with JPD, hence why we are changing the permissions. To take advantage of project permission management features, upgrade your plan.
Jet
11 comments
