Sign up Log in
JPD integration with Goals and Projects (ex Atlas)
497 comments
Tanguy Crusson
November 23, 2022
Jimi Wikman
November 23, 2022
@Tanguy Crussonwhat an amazing response!
Thank you, I will marinate your reply a bit and then give you a follow-up on it :)
Tanguy Crusson
November 25, 2022
Hi everyone, the Atlas integration is ready for you to use! To start using it simply add the "Atlas goals" or "Atlas project" fields to a list view and follow the prompts
Like 3 people like this
Jan-Hendrik Spieth
@Tanguy Crussonlooks like the fields are not available for us. If possible, please include us (audials.atlassian.net) in early access, thanks! :-)
Tanguy Crusson
November 27, 2022 edited
@Jan-Hendrik Spieth I just checked and you should have access. have you tried refreshing your browser window? If it still doesn't work we'll check it out in the next couple of days
Like Jan-Hendrik Spieth likes this
Jan-Hendrik Spieth
@Tanguy Crussonworks now, thanks!
Jan-Hendrik Spieth
Quick feedback after wiring up a few ideas:
  • The reending of multi-select fields in lists doesn't work all too good for Atlas Goals: even if we keep goal titles fairly short, they will usually be a couple of words long. Works ok-ish when only one goal is selected, but for several goals, typical column widths don't suffice. Idea: render one goal per line
  • JPD ideas don't seem to surface in Atlas, at all. As a (product) manager who is looking for next steps to take towards a goal, I'd like to be able to see/access a list of ideas that we have for the goal.
Like 2 people like this
Ben Gallant
Hey there :) I'd like to have access!
Ákos Botos
November 29, 2022 edited
Hi @Tanguy Crusson
Any chance making Atlas projects filed multiselect like the Atlas goals is. The use case is delivering an idea in iterations V1, V2 which may be far away in time therefore have their dedicated Atlas projects. Still we would like them to be connected to the same Idea (Demand in our case).
Multilevel ideas could solve the issue as well ;)
Andrew Durden December 5, 2022
Hey @Tanguy Crusson could I please have my company added to this early access list?
Would love to test out the Atlas integration as we are loving Product Discovery so far.
David Spire
Hi there,
Is there any possibility to filter on Atlas Project?
I see it's only possible to Goal or Project status.
David
Tanguy Crusson
December 6, 2022
@David Spire not yet. Do you link the same atlas project to multiple ideas?
David Spire
Yep, in our structure, we target to have a Goal that consists of Projects (we manage as yearly Impacts), and each Project is liniked to a product backlog of ideas inside JPD
Tanguy Crusson
December 8, 2022
@David Spire we're looking into it
Like David Spire likes this
Kirk Brohman December 9, 2022
@Tanguy Crusson +1 for testing the Atlas integration.
Dave Nicholson
@Tanguy Crusson could I get access to the integration?
Don Dresser
December 9, 2022
I'd be interested in trying this out :)
Britt Sikora Drake
December 9, 2022
+1 here too please
Iain McCarthy
+1 here also please @Tanguy Crusson, thanks!
Jules Arrighi
December 9, 2022
Would love to try out the integration! Thanks!
Matt Fraser
I'd like to test if possible thanks
JD
+1 here please!
Gavin Huang
December 11, 2022
I would like to try this out please
Megan MacDonald
December 12, 2022
@Tanguy Crusson +1 for the Atlas integration 🙏
Matt M_
Would like access to the Atlas integration please.
Upcoming Jira Product Discovery Events
