Sign up Log in
JPD integration with Goals and Projects (ex Atlas)
497 comments
Connor
December 1, 2023
Hey @Tanguy Crusson , could I get access to the Atlas integration? https://skywalkerholdings.atlassian.net/  Thank you!
Like • Tanguy Crusson likes this
Chris Ward
December 3, 2023
Josh Mihok December 4, 2023 edited
Is there a delay to have the new fields populated @Tanguy Crusson ? I see you have enabled them, but I have no options in Discovery in the pick lists.  Is this anything to do with domains?  My PD is https://bestegg.atlassian.net/ and Atlas is https://team.atlassian.com/ which is different than all our other atlassian products that share.  Thanks.
UPdate - a refresh worked so im all set.
Jared Polman December 4, 2023
Howdy Tanguy!
Hope you are doing well!
Can we please add it our site as well?
Please reach out for site URL.
Paige Wood December 5, 2023 edited
Can you turn this on for redacted, please? @Tanguy Crusson
Joshua Heling
@Tanguy Crusson we'd very much like to use the Atlas/JPD integration, too. I've just finished moving our backlog management into JPD, and we're also been experimentally dipping our toe into how to use Atlas, so it would be great to be able to unite these streams and get rid of our repetitive status reporting.
thanks!
Tanguy Crusson
December 7, 2023
@Joshua Heling I'll need your site URL
James Abram December 11, 2023
Hi, +1 please, thanks!
Peter Phillips
December 12, 2023
@Tanguy Crusson can I please get access enabled for domainpartners.atlassian.net
Gerald Gassner
December 13, 2023 edited
knowis.atlassian.net
@Tanguy Crusson could you please activate the trial for us as well? Thanks
joachim ramberg
December 17, 2023
@Tanguy Crusson  Would love to try out the Atlas/Goal integration aswell.
https://optiplan.atlassian.net
Freyr Guðmundsson
December 18, 2023
Hi! Could you please turn this on for us as well? https://lucinity.atlassian.net/  Thank you!
Jonathan Blackburn
@Tanguy Crusson , could I please have access for https://sandbox-pla.atlassian.net/ ?
Olga Svistunova
December 19, 2023
Hi @Tanguy Crusson could you please enable this integration for us, too? https://smileco.atlassian.net/ Thanks :)
Tomas Michalek
December 19, 2023
+1 Please
Very impactful for our workflow
Isaac Martin
December 20, 2023
Hello, I would like to request early access.
hendrik.schueler
December 21, 2023
@Tanguy Crusson +1 please, thanks!
Tanguy Crusson
December 22, 2023
reminder:
  • If I liked your message it's that I turned it on for you
  • If not, that means you didn't give me a site URL. Just add it and I'll give you access in the next few days, and like your message.
Like • Ward Weistra likes this
Michal Ovadia December 22, 2023
Hi @Tanguy Crusson
I've been using Jira Product Discovery for a few months now - it's really life changing!
Now trying out Atlas, and would love to see that integration in action.  Wondering specifically how easy it is to get the most recent comment/update on each Atlas project within JPD.
URL: https://ltccsdev.atlassian.net/
Thanks a ton!
Carlos Garcia Navarro
December 26, 2023
Could I get access to the Atlas integration as well, @Tanguy Crusson  (https://block.atlassian.net)? Thanks, and happy holidays!
Antal Vig _ Communardo
Could we get Access to the JSM/Atlas Integration as well?
https://communardo-demo.atlassian.net/
Joshua Heling
@Tanguy Crusson has this been enabled yet for our instance (https://verveindustrial.atlassian.net/)? I'm not entirely sure what the visible impact of it being enabled will be, but I don't see our existing atlas goals in JPD nor the current JPD goals in atlas.
Josh
Ward Weistra
January 3, 2024
Hi @Tanguy Crusson , can you please turn this (Goal sync between Atlas and Product Discovery) on for our team at https://firely.atlassian.net?
Ward
Brent Lewis January 3, 2024 edited
Please enable the Jira Product Discovery <- Atlas Goals integration in our instance here: https://asp-cloud.atlassian.net/jira
Upcoming Jira Product Discovery Events
