×Hi everyone,
Previously we provided more details about how Jira Product Discovery pricing was going to work, and in particular the new user roles: creator, contributor and stakeholders - with the ability for contributors and stakeholders to create ideas.
This post explains how to let contributors create ideas.
Open project settings:
Open “Features > Create ideas” and turn the feature on:
Contributors in your project will then be able to create ideas (but they won’t be able to edit them later)
Who will see this? anyone who has the "Create an idea" permission in this project - which we've added to the "Contributor" project role.
Note that only people who are unable to create and edit ideas in a project will see this button. If your project access is set to "Open" then anyone on the site with product access to Jira Product Discovery will be able to create ideas (instead of this "create an idea" feature). To change this behaviour, change the project access to "Limited"
(Note: people can also click on the Jira blue create button in the top navigation bar, but it's going to show the standard Jira experience for creating issues, we haven't yet managed to merge those)
By default the dialog will show summary and description fields:
You can configure it to ask users to specify more fields. To do this: create a view with the list of fields you want contributors to specify when creating ideas:
And choose this view in the Project settings > Create ideas:
Pro-tips
If you specify a filter in the view, Jira Product Discovery will try to edit the created idea so it matches the filter in the view (for example: setting the value of a “Triaged: Yes/No” field to “No”), so you can use it to keep the created ideas there until you’ve had a chance to review them
Instead of (or on top of) selecting a view, you can select an idea description template with a list of questions you want people to answer when creating an idea.
A quick demo:
Tanguy Crusson
Product @ Atlassian
Atlassian
Nice, France
277 accepted answers
147 comments
