Performance issues for the past couple of days
Some customers have been facing performance problems over the past couple of days.
Symptoms include:
  • The UI freezes for a few seconds when opening ideas or switching between different ideas
  • When closing the right sidebar with an idea, it may take a few seconds before being able to interact with fields on the view
We have found the root cause of the problem and implemented a fix - something was making the CPU shoot up to 100% for a bit - but it make take a bit more time before it reaches production. We're on it!
We apologize for the inconvenience.
Update on 9 December:
The issue should be fixed now.
Update on 6 December:
The fix has made its way to production but not yet released on some AWS regions. We expect it to be fully rolled out by Monday.
Update on 5 December:
we've been working on this for the past couple of days and found the root cause for this behaviour. Ironically, it was linked to a new library we're using to track UI performance metrics across Jira 🤨
Today's update:
  • Most of JPD should be back to normal between today and tomorrow
  • With the exception of the status field which may still play up and now we're focusing on that. The screen may still hang a bit when you try to update its value
  • While investigating all this we identified areas where we can improve performance further (the app gets re-rendered fully on some operations instead of changing just a part of the screen). We will fix that.
32 comments
Brett Sinn
December 3, 2024
Interesting. I'm not having these issues with Product Discovery, but with Jira.
Appreciate the helpful little notification though.
Like 2 people like this
jochen.goering
December 3, 2024
Thanks for the update. Actually I experience in overall Jira (not related to different project types) performance issues. Opening Issues e.g. takes quite long.
The behaviour is pretty bad in chrome, if I switch to safari it gets better. (quite confusing actually)
josh.fischer
December 3, 2024
Thanks for the update. Experienced this a bit yesterday, with Jira Discovery. There was a delay of a few seconds and on several occasions I received a Chrome warning offering me to "Kill" the process or "Wait".
Mandy Miller
December 3, 2024
Yes, I've experienced lags in click responsiveness in JPD yesterday 12/2/24 and today 12/3/24. Click, wait, then the men option appears. Select, wait, it's applied ... etc.
Jayson_Naidoo
December 3, 2024 edited
Also, experiencing this over the past 2 days in both Jira Product Discovery, in Jira and when looking at Plans.
Debra Brucato
December 3, 2024
Yes experiencing on JPD today 12/3/24
Edouard Kaiser
December 3, 2024
Hi everyone, thanks for your feedback and your patience.
We just applied some changes that we believe should mitigate the problems in JPD. To benefit from it, please fully refresh your browser tab.
If you still experience issues, please keep commenting and sharing more details.
We apologize again for the inconvenience.
Like Serhii Cherednychenko likes this
Jonathan Rue - Consultant December 3, 2024
Definitely been experiencing this in Jira Discovery.  Thanks for working on a fix.
Peter Quick
Just curious; can JPD problems like this can trigger action in Atlassian's Status Page system, which is where we go for info on disruptive problems.
We're seeing warnings about the performance problem in JPD.
PeterQ
Troy Cope
Yep, this was impacting me a lot yesterday! Thanks for the update.
Troy
David Schoen
December 3, 2024
"The UI freezes for a few seconds" is a stretch, I've waited a minute for some Jira pages to load today on a newish M3 MBP.
Why is this not on https://status.atlassian.com/ ?
Aditya Khokhar
December 3, 2024
Yes, I thought it was my system or Chrome issues, good stuff in capturing performance lag proactively and working towards it.
Víctor Valle Juarranz
December 3, 2024
Thansk for caring about the experience
Like Leon Oud likes this
Tanguy Crusson
December 4, 2024
@Aditya Khokhar @Troy Cope @Jonathan Rue - Consultant @Debra Brucato @Jayson_Naidoo @Mandy Miller @josh.fischer
Could you please refresh your screen and confirm if things work better for you now?
It looks ok on our end but it's a bit of a tricky one since we haven't been able to reproduce the issue consistently.
Peter Baker
December 4, 2024 edited
Same issue On Monday & Tuesday
Tanguy Crusson
December 4, 2024
@Peter Baker is that better today?
Leon Oud December 4, 2024
Issue is solved for me. Performance is actually better than before
Marcin Ruciński
December 4, 2024
I have to wait a very long time for the description or idea name, field name to be edited.
Tanguy Crusson
December 4, 2024
@Marcin Ruciński can you try refreshing your screen to see if it persists?
Marcin Ruciński
December 4, 2024
@Tanguy Crusson It works only for a moment. I have tried it on various browsers (except Safari).
Tanguy Crusson
@Marcin Ruciński Would you be OK to jump on a zoom so we can look at this together? https://calendly.com/tcrusson/15min-meeting
Note: that applies to anyone else facing this, we're keen to check what it looks like from your end :)
Like Marcin Ruciński likes this
Jonathan Rue - Consultant December 4, 2024
@Tanguy Crusson I am still experiencing the issue.  When I attempt to change status of an item in the Discovery project I get the following errors:
  • This page isn't responding
  • Reload Site? Changes you made may not be saved.
Tanguy Crusson
Okay - we shipped changes today which seem to have improve it for quite a few customers, but it looks like it's not enough. @Jonathan Rue - Consultant would you mind doing the following?
  • In Jira product discovery
  • left sidebar > give feedback
  • select "get help from the support team"
  • paste the following:
"Tanguy Crusson from the JPD team asked me to create this support ticket so the team can investigate a performance problem we're facing in the tool today - he told me they'd need access to our site to figure out what the problem is"
If you can do that we can run specific tests in your site and get to the bottom of this. If you do that, please let me know and I'll chase it up with the support team 🙏
@Tanguy Crusson Done.
Like Tanguy Crusson likes this
Tanguy Crusson
December 4, 2024
@Jonathan Rue - Consultant cool, found it. Once you approve data access we'll get on it with the team
