Hi community!
If you’ve created more than one discovery project, then you’ve likely also spent a lot of time deleting sample data. Well, we’ve heard you loud and clear - you want to get started quickly on a clean, blank canvas.
We’re excited to share we’ve just launched a new blank project template for Jira Product Discovery. This project template will come with system fields and empty list, board, matrix and timeline views so you can quickly and easily get started with your own data, instead of spending time deleting sample data.
Note the blank project template will not include any pre-defined custom fields.
To create a new project with a blank project template:
Select the Project dropdown from the top navigation
Select Create new project
Navigate to the Product management templates, select Blank project
Click Use template on the following screen
See it in action
And don't forget to sign up for the EAP on Global fields, so you don't even need to re-create each fields for every new project, just reuse the existing ones.
Cheers !
Hermance NDounga
Product Manager @ Jira Product Discovery
Atlassian
84 accepted answers
3 comments
