×Hello community!
We’re thrilled to announce two new features that will make it easier to manage fields in Jira Product Discovery: Global fields that can be used across discovery projects and a brand-new field management page 🚀
Global fields are custom fields that can be reused across multiple projects and different Jira products.
With this feature, you can create centrally managed fields: all field properties are the same across all projects and can be updated from a single place. Learn more
To create a new global field:
Go to the top bar and select ⚙️ > Products.
Under Jira Product Discovery, select Global fields.
Click Create global field, select the type of field you want to create, and click Create.
You want to standardize across different projects: you can now achieve consistent naming and options.
You want to reduce admin overhead: a field can be created once, updated once, and updates are automatically visible in all projects.
You are using two discovery projects and often move ideas from one project to another: global fields values will be retained when moving.
With the introduction of global fields, we’re also releasing a new field management experience that makes it easy to create new fields and add existing global fields to your project from a single page. Learn more 🔥
While Jira admins are the only ones able to create and modify global fields, thanks to this page, adding global fields to discovery projects can be delegated to project admins 👨🏼💻 for less friction.
To access the new fields management page, in your discovery project, go to Project settings > Fields.
Both of these features will make it easier for Jira Product Discovery users to achieve consistency across their projects, while at the same time reducing the burden on admins. We will continue making improvements to both features, so stay tuned!
Don’t hesitate to share any feedback on the feature using the “Give feedback” button in Jira Product Discovery or the comments below.
Hermance NDounga
Product Manager @ Jira Product Discovery
Atlassian
78 accepted answers
16 comments
