Hi there, and welcome!
We wanted to save you some trouble with a few things to help you get started with Jira Product Discovery. There are a couple of gotchas, so make sure to read this page before raising support tickets. We believe most of the product's "oddities" should be covered here when it comes to what site administrators need to be able to do.
Atlassian is currently rolling out a new billing engine, and the migration is not complete: in some sites, Jira Product Discovery is on a different billing engine than other Atlassian products, and you need to add payment details specifically for Jira Product Discovery.
If you don't do that, at the end of the trial period for the Standard plan, your plan will be canceled automatically, and users won't be able to access the product.
Here's a post explaining how to verify billing details.
If the number of users in the "Billing" section in admin.atlassian.com does not match the number of Creators you expect to have
Check out this video that explains how to check who is getting billed for Jira Product Discovery and common reasons why that number is higher than you expect (and how to fix that).
This assumes you already understand how Creators and Contributors work.
There are two types of users: Creators (billable) and Contributors (free)
It's described in more detail here.
Product role: Defines whether a user is a Creator or a Contributor to the site.
Project role: Defines the list of permissions in a project. These permissions limit the project features users can access when given a set of permissions. Users can have different project roles in different projects. Here's a video that explains this in more detail.
How do I add contributors to a Jira Product Discovery project if they don't have a Jira license?
Head over to our documentation to learn how to add contributors to a project.
Note: if you started using Jira Product Discovery during the beta, you'll first need to create the Contributors user group.
If the feature is turned on for them, Contributors can create ideas in a Jira Product Discovery project via a configurable form but not edit them. This post provides more details.
Edit: if you moved to the Free or Standard plan from 19 July 2023 the following two steps should not be needed anymore 👇
Site admins will count as billable users by default, here's how to change that
If you just added Jira Product Discovery to your site, you'll notice that all site administrators have been given product access to the product - and consume a license. This is because whenever a site administrator adds a new Atlassian product to a site, the site-admins user group is automatically given access to this product.
To fix this, remove access to Jira Product Discovery from the site-admins user group. Then, you can give product access to the people (product managers) you want to try the product instead.
This video shows you how to do it.
Note: if you see a different admin experience, check out the comments below this post 👇 for another way to do this.
Trusted users (a deprecated user experience) will also use a license for all products on the site. The only workaround in this case is to change the user's role to either Basic or Site-admins, after removing product access from the site-admins group.
The only workaround in this case is to:
Remove product access from the site-admins group.
Change the user's role to Basic or Site-admins. Ensure past trusted users' roles are also changed or they will continue to consume a license.
Tanguy Crusson
Product @ Atlassian
Atlassian
Nice, France
302 accepted answers
67 comments
