500 sub-issues limit
Seth Mason
We've randomly seen JPD ideas display the Delivery Status field on the right side pane with the text in a popout message: "We could only calculate the delivery data partially, because you've hit the 500 sub-issues limit."
These issues do not have 500 epics (or epics+subtasks) linked to them.  Is this 500 epics+tasks+subtasks for all ideas in JPD?
stephen.otoole@stemcell.com
November 4, 2024
Are there currently any issues with extending the limit?
Hanna
July 28, 2022
Hi @Seth Mason
We had to implement a limit because some users had 10000 linked issues in delivery and this was causing a 429 error for them limiting their access to Jira Software.
The limit applies to the Jira Product Discovery project, not per idea.
If you haven't encountered any issues with accessing Jira Software we can disable this limit for you. If you want to proceed with that, please provide your site name.
Best,
Hanna
Seth Mason
I don't have 10k linked epics/issues from JPD.  I'm not running into any other issues beyond this popup.  How can I DM you my instance or can you just pull it from my email address?
Erin Mihalik
@Hanna  We are going to need that limit removed or changed.  I only have 10 ideas in here yet I am encountering the error.
I think people hitting over 10k is going to happen easily if Subtasks are included.  One could make the argument that Subtasks should be filtered out in Delivery and only standard issue level or higher is returned.  As a product leader, this is not where we will run scrum off of so understanding the subtasks is not 100% necessary.
Erin Mihalik
50 Ideas in here with one epic each = 50 issues plus potentially 9 user stories in each epic is immediately 500.
Like • Seth Mason likes this
Erin Mihalik
May you please disable this on appetize.atlassian.com and spoton.atlassian.com?
Like • Hanna likes this
Hanna
July 29, 2022
Hi @Erin Mihalik
We'll disable this limit for the provided sites.
Hanna
July 29, 2022
Hi @Seth Mason
Feel free to share the site name here or DM it to hsazonava@atlassian.com.
brent.johnson
Hey @Hanna - can you disable this limit for our team? getmaple-ca.atlassian.net. Thanks!
Hanna
September 5, 2022
Hi @brent_johnson
It's now disabled for your site. (sorry for the delay, just got from a leave).
Best,
Hanna
Like • brent.johnson likes this
brent.johnson
September 6, 2022 edited
Thanks! And welcome back :)
Andrew Durden January 12, 2023
Hey @Hanna
Could you please remove this limit from rccl-idd.atlassian.net?
We are realizing we hit this 1000 sub-issue limit very easily.
Andrew
Hanna
January 13, 2023
Hi @Andrew Durden
We have removed the limit for the respective site.
Cheers!
Like • Andrew Durden likes this
Benedict Lubik
Hi Hanna,
I've come across the same issue, is there a way to turn this off by now?
BR, Benedict
Andrew Dunn
April 24, 2023
Hi @Hanna,
Can we also please have this limit removed from our site - connectrn.atlassian.net?
-Andrew
Hanna
April 25, 2023
Hi @Andrew Dunn
The limit was disabled for connectrn.atlassian.net.
Cheers!
Hanna
April 25, 2023
Hi @Benedict Lubik
It's possible to disable the limit. If you'd like to proceed with disabling, please share the site name.
Cheers!
Like • Benedict Lubik likes this
Andrew Dunn
April 25, 2023
@Hanna we are still experiencing the limit in Product Discovery. Are there specific steps we need to take to have the limit fully removed?
Holly Holbrook
Hi @Hanna can you please turn this off for https://nylas.atlassian.net/
Please and thank
Hanna
April 26, 2023
Hi @Andrew Dunn
This might be related to the current work and a bug the team uncoverd, see details in the thread  https://community.atlassian.com/t5/Jira-Product-Discovery-questions/1000-Sub-issues-limit/qaq-p/2341506.
We expect it to be solved in the next weeks.
Hanna
April 26, 2023
Hi @Holly Holbrook
Could you share the message you get in the UI about the limit?
It might be related to the work described in the thread here https://community.atlassian.com/t5/Jira-Product-Discovery-questions/1000-Sub-issues-limit/qaq-p/2341506.
Benedict Lubik
@Hanna Please disable it for https://i3dhub.atlassian.net/. I don't expect that we will see any issues since we don't exceed it by that much.
Holly Holbrook
@Hanna I'm getting this error. I think you're right :) "We could only calculate the delivery data partially, because you’ve hit the 1000 sub-issues limit."
Hanna
April 27, 2023
Hi @Benedict Lubik
The error you see is related to the bug we identified. You'll see this error even if you don't hit the 1000-issue limit. It's going to be fixed soon.
Find more details here in the thread https://community.atlassian.com/t5/Jira-Product-Discovery-questions/1000-Sub-issues-limit/qaq-p/2341506.
Erin Mihalik
July 27, 2022 edited
Deleted answer since I was wrong :)
Erin Mihalik
But this should only be "per each idea" not per JPD instance.
Seth Mason
We do not have any JPD ideas linked to issues higher than epic.
Hanna
July 29, 2022
Thank you @Erin for the feedback, I informed the team to look into addressing it.
