Ability for Contributors to Export views/lists
Andrew Lintag October 21, 2024
Hi all,
Sorry if this has already been asked! I'm working with a few internal stakeholders (services and support teams) on accessing JPD for updates to ideas or requests they submit on behalf of their customers.
One question that has come up is on how they can export the lists on their own so that they can put that together with other items that aren't ideas, i.e. work that doesn't require product research or development, when presenting project or status updates in their meetings.
As a contributor, the export/cloud download button shows but when it is clicked, it says that they don't have permission.  Based on the permission settings, it doesn't seem like a Contributor will be able to export views.  Is this correct?  If so, is there anything planned to allow them to in the future?
I'm also trying to come up with alternatives in case the above is true:
  1. What would happen if I duplicate the Contributor role and give them a permission that is marked for Creator (i.e. Export a view)?  Would that result in that duplicate Contributor role being treated as a Creator type role?
  2. Is there a way to surface the latest comment as a field in the view?
5 votes
Tanguy Crusson
October 21, 2024
Hi @Andrew Lintag , I just checked and you're right! Only creators can export. Let me discuss with the team to see if we could give it to contributors (it does seem to make sense)
Gregory Warner
December 12, 2024
I came here to ask the same thing, we have a client contributor who would like download access so control over that or making it default for contributors would be great.
Andrew Lintag August 5, 2025
Hi @Tanguy Crusson , I wanted to follow up on this to see if there are any plans to make this available. We're using PowerBI to allow for these exports but it takes the user out of the views, which doesn't allow them to interact with the ideas for more information in the comments, etc.
Jens Schumacher - Released_so
Hi @Andrew Lintag, alternatively you could take a look at Released.
It allows you to create a board view with tickets from Jira, JPD and JSM project, specifically build for presenting project plans / status.
