Associating Custom Fields from JPD to Software Project
Abby Kiesling
May 9, 2023 edited
I am trying to create an automation where, when an Idea in JPD is transitioned to "Selected for Development", a ticket is automatically generated in my engineering software project, but I am unable to make this work due to custom fields that are required in the software project.  Additionally, I want to include some important fields from JPD into my software project.
The issue I'm running into is that Jira doesn't know that Field A in my JPD project is the same thing as Field 1 in my Software Project, and I cannot for the life of me figure out how to code JSON to make it work.
I should also note, I can find the custom field ID for the software project fields, but I can't figure out how to get the IDs for my JPD fields.
Martin
Hi @Abby Kiesling
I have that automation build. To copy back and forth fields. I use {{triggerIssue.Field Name}} or {{issue.Field Name}}
I found that I can use the whole name with spaces even, as long as it matches
Ex: {{triggerIssue.Salesforce Case Number}}
Abby Kiesling
May 10, 2023 edited
This worked!!!! Thank you very much.  I did have to make sure my fields were the same type and the options were all exactly the same.  Once I corrected that, your fix worked like a charm.
Like • 2 people like this
Omer Meshar
May 10, 2023
@Abby Kiesling did you try getting the IDs from:
https://<your jira instance>/rest/api/2/issue/<a jira issue's key>?expand=names   ?
Did you try automation, where you can copy the value of Field A into Field 1?
Abby Kiesling
This was SO USEFUL for so many different things.  Thank you Omer.  I'm saving this link template for future use.
Like • Omer Meshar likes this
Warlen Xavier Cintra
May 9, 2023
Oi Abby, tem um campo de acesso JSON que p0ode dar acesso, MIT, tem um exemplo de ID que auxilia, deixo link:
https://stackoverflow.com/questions/8163859/how-can-i-get-data-in-json-array-by-id
Qualquer coisa tento a montagem de linha de pensamento. E obrigado.
Abby Kiesling
Hey there, thanks for the suggestion.  I'll check it out.
