Authorization issues with GRAPHQL
KB
I want to build an export for insights from JPD, given the product does not offer any method of it. I found it hard to leverage the graphql API but managed to put together the components in GraphQL explorer.
Now trying this in a node app, I get the error:
Auth category: UNAUTHENTICATED is not allowed in service polaris
This is how I put together the request:
I also copy the token from https://id.atlassian.com/manage-profile/security/api-tokens
const response = await fetch('https://MYINSTANCE.atlassian.net/gateway/api/graphql', {
        method: 'POST',
        headers: {
          Authorization:'TOKENcopiedFROM-https://id.atlassian.com/manage-profile/security/api-tokens',
          'Content-Type': 'application/json',
          'X-ExperimentalApi':'polaris-v0',
        body: JSON.stringify({
          query: `query myquery {
            polarisInsights(project: "ari:cloud:jira:MYCLOUDID:project/PROJECTID",
                    container:"ari:cloud:jira:MYCLOUDID:issue/`+id+`") {
                      id
Not sure about the Token format, but from what I found this would be it.
I appreachiate any help!
KB
I found the solution. Unfortunately the documentation is really bad for this. With the help from the support team i figured the resolution:
First, the domain you use does not matter.
Second the authorization:
'Authorization':"Basic InserTokenHere"
and the token needs to be created by this string in  base64 encoding:
your@emailaddress.com:MYTOKEN-copied-from-https://id.atlassian.com/manage-profile/security/api-tokens
Hermance NDounga
March 15, 2024
Hello can you please try using this URL https://api.atlassian.com/graphql instead  of
it should work :)
Hermance
KB
Thanks Hermance, unfortunately it does not change a thing.
How should the Authentication be formated?
Thanks & Best
Kornelius
KB
@Hermance NDounga Can you share some details o n the Aut token format, or if there is anything else to consider here?
