We opted to have the Project Target field automatically updated by the linked delivery ticket, but upon changes, there is no mention in history.
Is there a way to automate a comment upon date changes in linked ticket?
Hello @Matteo Pacenti ,
Good day, Welcome to Atlassian Community !!
Yes, you can use "Automation for Jira"
Trigger: When field value is changed for a Project Target field.
Branch: for Linked Issues "Add the link you are looking for"
Action: within the Branch add action: Add comment: Project Target field is: {{triggerIssue.customfield_ABCD}}
ABCD is your custom field ID
Let me know if you need Complete Rule created as well
if you could do in a short time much appreciated, in any case I will try myself right now.
I will come back if I have questions or issues
@Akhand Pratap Singh can you please share an example?
I tried but the automation never intercepts the autofill of the dates
Hey @Matteo Pacenti ,
As I understand these dates are getting edited by Automation for Jira only, based on the linked ticket, the rule that you created, please make sure under Rule details you check.
hello @Akhand Pratap Singh thanks for your input
I checked and my rule has that checkbox ticked.
I did a bit of test and if i update the date manually it works, but if the project target is updated by a delivery ticket due date, does not work.
Any idea?
