Cannot Publish View w/Atlas Project Field
Eric Seeley January 13, 2025
We are trying to link our Atlas projects to our JPD  Ideas. It seems to work fine, except when I go to publish a JPD roadmap view for external use. It does not allow it. Does anyone know if Atlassian is working on a solution to this?
Nick Haller
January 13, 2025
Hi @Eric Seeley ,
Doesn't look like this is currently listed on the JPD public roadmap, but maybe it falls into JPR-15Goals and Projects integration (ex Atlas).
Regardless, as a workaround - consider creating a hyperlink field(s) that represent the Atlas project, goal, etc. These can be published, and do show in the field like so:
I understand it's not ideal and requires duplicate efforts, but it would at least provide better visibility to these fields with whomever is shared the published view.
Tanguy Crusson
January 15, 2025
Hi , I can confirm we do plan to add this support, but not in the short term.
Like • 2 people like this
