Connections: Board view of Opportunity, Solution and Iteration
Steven Mullin
September 15, 2025
I'm using Connections feature (its great!!). Is there a way to get 3 layers into the Board View? Id like the Ticket to be the Opportunity with a list of Solutions including Iterations per Solution.   I can get Opportunity Tickets with Solutions listed inside and I can get Solution Tickets with Iterations inside but I have not figured out how to get all 3 layers.
2 accepted
Beata Kupiec
September 17, 2025
Hello Steven and welcome to Community!
If you connect all Iterations and all Solutions to the Opportunity you will see them displayed on the card on the board view however there's no current way to display Iterations by Solution, so you can get:
- Opportunity
   - Solution:
A
B
C
   - Iteration
A
B
C
However you cannot get:
- Opportunity
 - Solution:
A
 - Iteration
A
- Solution
B
- Iteration
B
Beata Kupiec
Principal Product Manager @ Jira Product Discovery
Tanguy Crusson
September 17, 2025
The only way to show 3 levels is like this:
  • Level 1: Group by: Opportunity
    • Level 2: Filter the board to show: Type = Solution (those will be the cards on the boards)
      • Level 3: add the "Iteration" field
Which gives you something like this:
Steven Mullin
September 19, 2025
TY both very much for the detailed responses!
