I'm experiencing a couple of shortfalls on the Create Idea form that contributors (not creators) can use to submit new ideas:
Am I missing something, or is this not currently available functionality?
Hi @Jaime Laird , you are right about #2, it's a limitation.
As for #1, they can add the insight after creating the idea.
Thanks @Tanguy Crusson
Regarding insights - I think the idea is that the contributors will be able to add these after they submitted the idea. Same goes for creators - they also can't add insights before the idea is created...
As for mandatory fields - it is a current limitation.
I would add also the limitation of having a single form, since many of our creators prefer the 'Create' button over the 'Create an idea' button (but need other fields to fill).
