I'm trying to set up an automation rule in my Discovery project with a 'create variable' action using an IF formula.
This is what I entered, but I keep getting 'Parameter not closed' errors, but I don't know what I'm doing wrong!
{{#if({{issue.customfield_10105}}.lt(3),{{issue.customfield_10105}},{"0 - {{issue.customfield_10105}}*100")}}{{/}}
This is the IF formula i am trying to create:
I'd be grateful if anyone can help me!
Hi @Silas Campbell -- Welcome to the Atlassian Community!
You appear to be trying the format of if() function which has true / false values: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-conditional-logic/#if
That format is this: {{if(smartValue, "value if true", "value if false")}}
Please note there is no pound sign # before the if() and once inside of the expression, no additional curly brackets are needed. Also, you cannot use a literal value of 0 directly as the expression values are text and not within a math expression.
You seem to want to negate the field value and multiple by 100 for the "false" case, so perhaps try this instead:
{{if(issue.customfield_10105.lt(3), issue.customfield_10105, issue.customfield_10105.multiply(-100))}}
Read the story
