Custom Formula for Progress Tracking in Jira Product Discovery
Pradeep
March 11, 2025
Hi Jira Community,
I’m trying to create a custom formula in Jira Product Discovery to track project progress based on three custom single-select dropdown fields:
  • Schedule (Values: "On Track", "At Risk", "Off Track", "Needs Review")
  • Scope (Values: "On Track", "At Risk", "Off Track", "Needs Review")
  • Resourcing (Values: "On Track", "At Risk", "Off Track", "Needs Review")
I created a 4th column called Progress and attempted the following formulas.
IF(AND(Schedule = "On Track", Resourcing = "On Track", Scope = "On Track"), "On Track", IF(OR(Schedule = "Off Track", Resourcing = "Off Track", Scope = "Off Track"), "Off Track", IF(OR(Schedule = "At Risk", Resourcing = "At Risk", Scope = "At Risk"), "At Risk", "Needs Review") ) )
ISSUE : Could not parse expression issue is displayed.
Questions:
  1. Are dropdown fields referenced differently in Jira Product Discovery formulas?
  2. Is there a better way to achieve either a status-based ?
Would appreciate any help.
Pradeep
Amina Bouabdallah
March 14, 2025
hi Pradeep! you will need to use automation for these advanced formulas, they cannot be used in custom formulas. Hope this helps!
