Data dump of all history
Ben Krichko October 2, 2023
Is there a way a to pull a full export or data dump of all the History under a JPD Idea? This would make finding timestamp changes MUCH more efficient. Maybe an export button?
Mohamed Benziane
Give a try to the API, i know it for Jira Software but i think it should be possible to get the ideas and the history using the param"?expand=changelog"
https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issues/#api-rest-api-3-issue-issueidorkey-get
Ben Krichko October 3, 2023
Thanks @Mohamed Benziane !
I'm fairly new to API calls in Atlassian. I have created a separate API token and am using Postman to make the calls, but am getting stuck on a 401 error. Is this something we can pair on and you guide me?
Mohamed Benziane
@Ben Krichko
Did you use your mail address in the username field on postman ?
@Mohamed Benziane
There are several auth options within Postman. I started with Basic Auth. I have put my email address in the Username field, but I think my problem is the password field. Would that be the full API token generated from Atlassian or something else?
Mohamed Benziane
Yes you nned to pu the full API token in the password field
Ben Krichko October 3, 2023 edited
@Mohamed Benziane  You are awesome!! I'm now pulling a 200 response code. Last piece, For  the param"?expand=changelog", how should that be entered?
Like • 2 people like this
Mohamed Benziane
@Ben Krichko
Just put the param at the end of the URL like this
myAtlassianSite/rest/api/3/issue/{issueIdOrKey}?expand=changelog
Like • Steffen Opel _Utoolity_ likes this
Rohan Swami
October 2, 2023
