Sign up Log in
Dates in Published Views do not match Project view
Hiro Shimozato April 8, 2024
In JPD, my understanding is that the date fields displayed in the discovery project view are supposed to be the same as what you see in the published view. For some reason, the date fields are not showing the same information.
I have one date field ("Effort Start") configured to autofill based on the linked delivery tickets. The other field ("Solution Availability") is manually set.  It looks like the autofilled fields are not displaying correctly in the published view.
Anyone else experiencing this?
Screenshot 2024-04-08 at 6.24.37 PM copy.png Screenshot 2024-04-08 at 6.23.51 PM copy.png
Kostia
April 9, 2024
@Hiro Shimozato Hi, Kostia engineer from JPD team here. Thanks for reporting this, we are aware of this problem and working on solving it. We will let you know once it is fixed.
Hiro Shimozato April 9, 2024
Thanks, Kostia
Hiro Shimozato April 18, 2024
Hi Kostia - can you tell me when you think a fix will be deployed?
I have a bunch of process that relies on the published views that I'm holding back from deploying to my org because of this issue. It's not a usable feature unless the dates are consistent.
If it's going to be a while before this gets addressed, I need to find a temporary workaround or alternative solution. So it would be great to get some understanding of timing.  thanks
Kostia
June 4, 2024
@Hiro Shimozato Hi! Sorry for taking long for response. We have fixed the issue and it is deployed to everyone.
Like Bartosz Cytrowski likes this
Upcoming Jira Product Discovery Events
