×I often create ideas or add insights from comments in slack by right clicking on an slack message and then creating the idea. I'd like to avoid the automated message that says an idea/insight was created. I did not connect my JPD project to my channel (JPD Project -> Settings -> Slack Integration). Is there a way to either 1/hide these messages so they aren't displayed or 2/ make them private so that only I see them?
-Seth
Hi Seth, thanks for the feedback - you can't disable that behaviour currently unfortunately
