Field Permmisions
Hari February 19, 2023
As a admin i am unable to restrict Members changing Due date, Target date. i am using payable software , adqprojects.atlassian.net, kindly guide on same.
Ivor
February 20, 2023 edited
I believe you cannot control view/edit permissions per custom user role at the moment yet, as JPD is on team managed project and that doesn't allow you to customize the permissions/roles.
It has been requested, but no news about it in the roadmap. You can try to vote it to get into subsequent releases.
https://community.atlassian.com/t5/Jira-Product-Discovery/Permission-to-remove-a-field-from-a-view/td-p/2104759
Rohan Swami
February 20, 2023
@Ivor is correct, @Hari. This isn't on our roadmap at the moment. However, we are introducing creator and contributor roles, where contributors are restricted to certain interactions like viewing, commenting and voting. Contributors won't be able to update field values. Would that solve for your use case?
Hari February 20, 2023
Mr.Rohan, is this issue for all Atlassian products or particular products only.
Rohan Swami
February 21, 2023
@Hari you can restrict updating certain fields in Jira Software, but it's not supported in Jira Product Discovery at the moment.
Hari February 21, 2023
thanks for the update Mr.Rohan, if you don't mind can you explain how can we restrict in Jira Software, Hope i can correct if i am wrong.
Rohan Swami
February 21, 2023
