Sign up Log in
Filter ideas without date
Aurélien BARBE
April 12, 2024
Hello everyone,
is it possible on a list view to specify that I don't want to display ideas where I don't have a date specified in one of my date fields.
Currently, if I choose to add a filter on a date field, I don't have the option :
thanks in advance
Ste Wright
April 12, 2024
Hi @Aurélien BARBE
You can do this from a normal issue search page using JQL?
  • On the top navigation bar, select Filters > View all issues
  • Enter JQL for this, for example...
    • project = "ABC and "Date de debut" is EMPTY
^ Ensure you select the right field when doing this, as JPD is still using a Team-managed model, although there is a beta running for global fields
However, I don't think it's possible to modify the filter in your image any further in the list view.
You could suggest this? You can raise feature requests through here: https://jira.atlassian.com/secure/Dashboard.jspa
A potential workaround is to use Automation to populate a checkbox field, then use this in the filter instead?
The field would be editable, and you would need to be careful of execution limits - i.e 200 for Free, 500 for Standard per month (see execution limits on this help page), but it's an option?
Prerequisites:
  • Create a custom checkbox field, eg. "Date Populated?"
  • Get the custom field IDs of both the date field and the checkbox field
    • See all fields here - https://<your instance>.atlassian.net/rest/api/3/field
      • Search for the fields using their names
      • For this example, Date de debut is ID 123456, and Date Populated is ID 654321
Rule:
  • Trigger: Field value changed
    • Field to monitor = Date de debut
    • Change type = Any changes to the field value
  • Condition: IF or ELSE
    • IF...
      • Condition: {{smart values}} condition
        • First value = {{issue.customfield_123456}}
        • Condition = equals
        • Second value = Empty - leave empty, don't type in the word
      • Action: Edit issue
        • More options...
          • Additional fields...
              "fields": {
              "customfield_654321": 0
    • ELSE-IF...
        • Condition = does not equal
        • More options...
              "fields": {
              "customfield_654321": 1
Notes:
  • You have to use smart values/JSON in the Conditions and Actions as JPD fields aren't available to select from the field menus.
Let us know if this works for you!
Ste
Aurélien BARBE
April 15, 2024
thank you for this more than complete answer.
For the time being, I'm going to use JQL. It'll help me make sure I'm on the right track with the processes I want to implement.
And thanks for the tip about automation. Maybe I'll use it to centralize everything in JPD.
Miguel Ramon
Not entirely sure, but would it work for you if you do it from the issue search window? From there you'd surely be able to run a query such as:
project = XXX and "date_field" is EMPTY
This can be run  by accessing https://<your_instance>.atlassian.net/issues/
Upcoming Jira Product Discovery Events
