×This is probably easy and I'm missing where I can do this... but how can I delete one or more fields that are no longer in use?
1. You need to be an admin
2. In the table view, i can click on "fields" to see the list of fields
3. Then clicking on the snowman (three dots), I can see Edit Field, Remove from view, and Delete
Hope that helps
Thanks for the quick answer @quan! I knew it was somewhere.
Thanks @quan !
Where were you looking for it @Brent Johnson ? We keep adding this menu in more places as this question keeps coming up :)
Hey @Tanguy Crusson Here's the order of the two places I looked:
Ah yes, I forgot about that path! We'll add the "delete field" there too, when opening fields from the idea view.
