Insights from Email into JPD?
Mel Hungate
I'm wondering if there's a clean way to get an outlook email thread added as an insight into Jira Product Discovery?
3 votes
Tanguy Crusson
October 28, 2022
@Mel Hungate today it's only possible if you use the Web version of outlook, using the Chrome extension, to add parts of an email as an insight to an idea.
Tere Pile
@Tanguy Crusson Question is will JPD support the Outlook app eventually as a 'link' even if not part of insights
Technically outlook app it 'works' w/a pretty big flow, no attachment:
I can search an item and find the JPD ticket, I can select add email, comment and paste body to comment - it accepts the action - but ticket does not actually have the attachment, it will show the comment(s) only.
I can create from outlook - but its an empty shell of a ticket w/no attachment.  Now if I use the "paste email contents" to description, that provides the detail, but the email is still not 'in JPD'
Eleanor Jarvis
May 21, 2025
Hi @Tanguy Crusson
Is there any update to this? I can add an email as a comment to a JPD idea by using the Jira Cloud app for Outlook, but I really want to add this as an insight.
Using the web version of outlook with the browser extension pulls through loads of formatting characters, which makes the emails impossible to read in JPD.
Thanks for your help!
Eleanor
Jan-Hendrik Spieth
October 20, 2022 edited
If creating ideas from a single mail message, or adding certain text snippets to a new idea or to existing ideas, sounds interesting/useful:
Try opening Outlook in Edge (or Chrome of course), and use the Google Chrome extension. Edge is Chromium, so the extension works there, as well.
Also, and I haven't tried this - but I think it's possible - you can do sth there via Power Automate. Here's a template that looks promising for starters:
https://powerautomate.microsoft.com/en-US/templates/details/7619073fdfe0468d996406eeaec3238e/create-an-issue-in-jira-for-a-flagged-email/
