×Is there a limit to the number of fields per project in JPD?
If there is a limit, do global fields used in a JPD project count against the limit?
Thank you
Hi @PATRICIA MURPHY,
Yes. As per this support article there is a limit of 200 fields. Given the suggestion to either remove fields or detach global fields from your project in case your run into the limit, yes: global fields count against the limit as well.
Hope this helps!
