×Hi!
When in certain Idea card view we can "Pin" certain fields above but still there are so many fields that we have available, which are of great use to us in different tables, lists, plans, roadmaps... but when it comes to the single Idea view with so many fields enlisted, we have reduced clarity.
In the Jira Cloud, we have a way to configure every single view and page, but we do not see this option available in the JPD.
Are we missing something or this is not (yet) available in JPD?
Thank you!
Krešo
Hi @Kresimir Linke ,
No I don't believe you are missing anything. As you mentioned, the "Pinned fields" appear in the top section of an idea's right panel. Following that will be the "Fields in this view" section. And finally, there's the "Available fields" section.
Each section will "save" if collapsed and/or expanded when navigating between ideas, regardless of switching between views. But this is on a user-by-user basis. There isn't a way to save/default this for all users, or only limit an idea to either the Pinned fields / Fields in this view.
Feel free to share this feedback with engineering and product within JPD under the Give feedback tab though. Maybe it'll be something considered in the future!
