Is there a way to setup an automation trigger from JPD : "on Atlassian Project Status update"
Paul Goujon
September 26, 2025
Using the JIRA Product Discovery <=> (ex-)Atlas sync feature, I'd like to setup an automation that sets the JIRA Product Discovery work item's status field to "in progress", when someone transitions the linked Atlas Project status from "pending" to "on track" (for example)
Issue: currently, automations watching triggers like "fields update", or "work item update" (or even "work item transitioned") are not reacting to an "Atlassian Project Status" update.
Is this a known limitation ? Is there any workaround ? Or am I doing it wrong ?
September 26, 2025
Hi @Paul Goujon -- Welcome to the Atlassian Community!
Based upon the open suggestions, there is no support for Atlassian Home (formerly called Atlas) in automation rules.  Here are some of the suggestions if you want to watch / vote for them:
