JDP Project Visibility
Linda Kurtz
March 14, 2025
Who can see a Project under JDP?  We want it to only be the people who are working on it.  I want to make sure I have it set up correctly as someone outside of the team was able to see it.
3 votes
Gary Spross
March 14, 2025
  • Open or Limited
    • Anyone can view
    • Caveat being that they will at least need Contributor access to JPD as a product
      • This will automatically be the case for anyone licensed to Jira or JSM
      • If a user is not licensed to Jira or JSM, there is a contributors group for JPD they can be added to
  • Private
    • You'll need to set the group or user into the "Contributor" role within the project
NOTE: If you're on the JPD Free plan, all JPD projects will be set to "Open" access.
Linda Kurtz
March 14, 2025
Thank you! This helps a lot.
Like • Gary Spross likes this
Gary Spross
March 14, 2025
Happy to help! Please accept this answer to help others, with your same question, to find it.
