JPD - TImeline view - How do I color the individual idea bars in this view?
Lynn Wilson
The Timeline view in JPD is good, but it lacks the ability to color code the entire effort bar when visualizing.  With everything just black and white, its super difficult to differentiate categories of efforts, or draw attention to groupings/individual efforts in the view.    I'm using these timelines at the C level of my organization and having to recreate some of the visuals because of this roadblock.    I've tried putting labels and different categories on my  cards.  This all works fine and good in the roadmap view but again, is not visualizing in the timeline view.  What am I missing or is this just not available yet?  If not now... when?  Please and thank yoU!
Tanguy Crusson
August 21, 2024
Thanks for the feedback Lynn, you can't fully colour the cards yet.
However you can add multiple fields to cards in the timeline view if you use the compact or detailed layout for cards:
if you use the summary layout, you can add one field to the card:
Jeremy Drexler
Thanks for the update @Tanguy Crusson  - this isnt a blocker at all, but its interesting functionality to have. Is there a feature request where I can follow along to see if/when the work is prioritized?
Like Lynn Wilson likes this
Tanguy Crusson
August 27, 2024
Hi Jeremy, we don't have a public issue tracker yet - but you can watch the announcements we make in this community - we'll be sure to talk about it here when we start working on this
Jess Galloway
November 13, 2024
Just coming here to say that I would also like this same functionality. Particularly in the Summary view with no fields selected - it would help to visually separate what we're grouping by. Thanks!
Like # people like this
Seth Forbus
September 5, 2025
Adding an upvote for my organization as well, displaying at the C-Suite level and color coding would be very helpful.
Darryl Charman July 17, 2025
Also here to add my voice to this. I love the Product timeline view, and JPD generally is a great product. But presenting the roadmap timeline to C-suite is limited as there are limited config options. As an example, it's difficult to differentiate the white bars from the light grey background. Even having the ability to change the background colour would improve readability.
Rylan Maschak September 12, 2025
In lieu of a dedicated space to create and vote on ideas, I am adding my comment here to support it.
Our Product Management team would benefit from this customizability—for example, something similar to how it's done for Epics (Software Projects) in Plans > Timelime view, based on the selected colour for the Epic. The visual distinction can help.2025-09-12_14-42-55.png
