JPD Voting
Dan Foster June 4, 2025
Looking for the easiest and fastest way to enable voting within JPD. @Tanguy Crusson, saw that you had responded to a few other threads on this overall topic, so hoping that you can please chime in here. Thanks!
Tanguy Crusson
June 6, 2025
Hi @Dan Foster have you tried creating a field of type "Votes"? That's what it's for. Or "reactions" for a more lightweight version.
Dan Foster June 9, 2025
Thanks, @Tanguy Crusson . I thought that JPD had more built-in-functionality for stakeholders' ability to vote up/down ideas. Is that not the case? Thanks again
Tanguy Crusson
June 9, 2025
That's what the Votes field is for! What were you after?
Dan Foster June 10, 2025
it's exactly what i was/am after, @Tanguy Crusson . i just had assumed that that feature/functionality would have been in there (turned on/enabled) by default. hence, my confusion and apprehension here. but thanks for clarifying. much appreciated and stay well
Tanguy Crusson
June 10, 2025
perfect thanks!
Martijn ten Caat
I'm looking for something similar to this, but not exactly the same.
As more ideas are added, simply giving customers a fixed number of votes won't be sufficient.
I'd like a system where customers can upvote or downvote individual ideas. Ideas with the most upvotes should be prioritized for development.
Is there a way to implement this?
