JPD / Zapier
Kristina Schaaf September 12, 2025
Hi there, our team is actively using JPD for roadmap planning, and we’re looking for a way to connect JPD with Asana, where some of our downstream execution happens.
Right now, the only workaround we’ve found is:
  1. Exporting JPD Ideas into a Google Sheet using the Jira extension
  2. Using Zapier to import that data into Asana
It’s manual and brittle. We’d love to set up a Zapier automation that pushes new JPD ideas (or filtered ones) directly into Asana, similar to how you can do this with Jira Software.
Questions:
  • Is Zapier support on the roadmap for JPD?
  • Is there a workaround or API-based approach others are using in the meantime?
  • Could this be done with Automations + Webhooks inside JPD?
Would appreciate any guidance from the Atlassian team or other users!
Tanguy Crusson
September 15, 2025
Hi, have you tried using the "Jira Software Cloud" Zapier connector?
It should with JPD ideas (which are Jira issues in the backend)
