Is the ability to add types in JPD part of the Standard plan? The hierarchy seems to be a Premium feature, but I can still see the ability to add types in my Standard env.
Hi @Omer Meshar, yes the ability to add types is part of the Standard tier, only connecting those types is part of the Premium tier. We are on Standard and use multiple types successfully.
More info can be found here: Configure your type of ideas and their hierarchies | Jira Product Discovery | Atlassian Support
Correct: go go Project/Space settings > Types and workflows
