JSON writing a username error
Martin
Hi there,
When we create delivery tickets to execute an idea, the team manager will assign a responsable on the created EPIC. I want an automation to send this assignee value back to a JDP custom field that I called: Project Manger. The custom field ID is: customfield_10475
However, It's not working right.
My script gives me the error:
Error editing issues
OPJ-288 (data was not an array (customfield_10475))
Seams like I cannot go around that. My field type is: @ People field
May 25, 2023 edited
Hi @Martin
Please try using the accountId value, and not the displayName, to select a user in a single-select user field.  Here is the syntax for that:
https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Single-user-picker-custom-field
Chris Timms
May 26, 2023 edited
Hi @Bill Sheboy
Your solution does not tackle the reported issue, which is that the field entry is not in an array. Multi-user fields need to be added as arrays via automation even if you are only trying to add a single value. The error will be the same even if Martin tries the account ID. You cannot create single select use fields in JPD, I believe.
However, you have found the page I referred to in my answer, which demos this correct syntax for adding a field value in an array, so thank you!
-C
Chris Timms
May 25, 2023
Hi @Martin !
is your custom field a multi select field or can it only have a single value? If it’s a multi-select field, you need to format your request as an array even if you are only storing a single value. I can’t find the samples on mobile, but Jira’s smart value documentation has enough info that allowed me to solve the issue previously.
regards,
-C
