Jira Software Integration
Liora Naginsky
Hi!
Could you please provide the guide on connecting the Product Discovery to Jira Software?
Is this process automated? How does the integration work?
I we already utilize Jira and install Product Discovery, will data seamlessly transfer from Jira to Product Discovery?
Thank you!
3 accepted
Rohan Swami
April 2, 2024
Hi @Liora Naginsky you might find this Loom demo I made helpful in learning about connecting Product Discovery to Jira Software. Short answer: Yes, it does flow seamlessly!
Liora Naginsky
@Rohan Swami THANK YOU!
Aaron Pavez _ServiceRocket_
Hi @Liora Naginsky
There are a couple of resources you need to check first to understand how JPD works
https://community.atlassian.com/t5/Jira-Product-Discovery-articles/Product-Management-Practices-bookmark-me/ba-p/2384561
https://www.atlassian.com/software/jira/product-discovery/guides/ideas/overview#anatomy-of-idea
This YouTube video its really helpful:
https://www.youtube.com/watch?v=vZFJOcdAX0U
understand how the data will be transferred from Jira to Product
You can link any other Jira issue from your instance to an Idea.
Regards and happy learning!
Liora Naginsky
thank you!
Hi @Liora Naginsky
Please check here to understand what JPD is:
https://support.atlassian.com/jira-product-discovery/docs/what-is-jira-product-discovery/
https://www.atlassian.com/software/jira/product-discovery/guides/getting-started/introduction#what-is-jira-product-discovery
JPD is another type of project (Like JSM).
What kind of data do you need to add from Jira SW to JPD?
Regards
Liora Naginsky
@Aaron Pavez _ServiceRocket_ All data, like epics and USs.
We would like to build the roadmap in Product Discovery and would like to understand how the data will be transferred from Jira to Product (for example, US progress status).
I would like to see how we can set the integration.
Thank you!
Liora Naginsky
thank you!
