×Below I have a calculated field with just one positive and one negative entry (for testing, the final one has more items).
The calculated field show the values 100, 50, 50. This is correct with the blue "impact" field and once I change the blue field, all is calculated fine.
However, in the negative part (red field) this is not working, and negative values seems ignored.
The two 50 numbers should be diffent based on the red values.
Am I doing something wrong here?
