Multiple idea templates
JUDY EDMONDS
October 10, 2024 edited
I would like to send users down different flows depending on problem or idea but can only use one idea template from what I can see.
Is there a way to achieve this currently and then do some kind of branching upon idea entry?
Jeny Stoeva
October 11, 2024
hi @JUDY EDMONDS ,
Currently the idea creation form can be based on only one template and you can either make all fields mandatory or none (besides the summary which is mandatory).
It would be indeed great if multiple templates can be used for the idea creation. It is an old request and hopefully we get it sooner than later.
Joshua Gunter
January 30, 2025
Jeny, we would like this as well. Is there a place where we can go to upvote this feature request?
