Overview autosave
Julien Seiller September 13, 2023
is there any plans to autosave updates of the overview field?
Vlad Zinculescu
September 13, 2023 edited
@Julien Seiller I'd love to help you with an answer, but could you please provide more context, just to make sure I understand exactly what you'd like us to implement.
I mean that if you have a pretty long description, it could happen that you forget to save the changes.
Having an autosave function would be anyway more convenient.
Vlad Zinculescu
September 13, 2023
Currently, when you close an idea, the overview/idea description field saves everything that you've written ( for you only ) but doesn't publish for everyone else until you hit save.
But it seems you're suggesting a different feature. If I understand correctly, you're proposing the elimination of the 'Save' button altogether and instead implementing an auto-save feature that saves your work as you type. That's a great point. We don't have any immediate plans to work on this, but thanks for suggesting it.
