Posting Date in a JDP field
Martin
I am struggling with an automation. Simple, I want to add today's date to a custom field. I used the doc here: Product demo: Automation for Delivery 🤖 - Atlassian Community
Here is my statement:
"fields": {
"customfield_10552":"{\"start\":\"{{now.jiraDate}}\",
\"end\":\"{{now.jiradate}}\"}"
Here is the error I get:
Error while parsing additional fields. Not valid JSON.
Thank you for your help!
3 votes
Erin Quick-Laughlin
June 29, 2023 edited
I believe it's because of the quotes surrounding the object that contains start and end props.
When I post your code into jsonlint.com, it shows this:
After I took those out, it also threw errors on the escapes, so try this?
"fields": {
"customfield_10552": {
"start":"{{now.JiraDate}}",
"end":"{{now.Jiradate}}"
BTW what kind of custom field type is this?
Martin
Thank you Erin. I'm bookmarking this tool.
It's a date field in JDP.
I used the exemple provided by @Hermance NDounga in her documentation. Copy/Paste and changed the field number only.
Like • Erin Quick-Laughlin likes this
Martin
I asked also a new friend, that sometimes, knows a lot. His name is chatGPT. It gave me the right formula and it works:
In your JSON, there is a small issue with the casing of the jiraDate placeholder. In Jira Automation, the correct casing for the current date placeholder is {{now.JiraDate}} with an uppercase "J" and "D".
Here's the corrected JSON:
"fields": {
"customfield_10552": "{\"start\":\"{{now.JiraDate}}\",\"end\":\"{{now.JiraDate}}\"}"
This JSON assigns the current Jira date to both the start and end properties within the customfield_10552 field.
Chris Timms
June 29, 2023
Commenting to track if anyone comes up with a solution to this one. My own investigation suggests it might be related to escaping special characters correctly, bbut I haven't been able to invest the time to look into it deeply.
-C
