Hey everyone!
Is it possible to rearrange columns in a table view (eg. impact assessment). I havent been able to find any context menus and drag-n-drop doesnt seem to work.
Currently using Firefox.
Hello!
Yes, you can rearrange the columns by dragging up & down the fields in the field selector window clicking on the 6 dots that are left to the icon
Thank you @Antonio Valle (G2) !
Yep, that's the workaround for now - we're actually working on a new list component which makes that possible via drag&drop, and enables a whole lot of other use cases (fixed header row and column, group by a field in a list, etc.)
