Show an idea in a view based on date
Adrian.Lester
I've a select field, Stage, that I use to track ideas through their lifecycle, and several views that group by the Stage field.
I'd like to show ideas that have moved into the final Stage (Monitoring) for 2 weeks and after that they disappear from the view.  I can't figure out how to filter by the Updated field, nor can I figure out how to set a date field via automation when the idea moves to Stage = Monitoring.  Any suggestions?
Jens Schumacher - Released_so
October 10, 2024
Hi @Adrian.Lester I don't think this is currently possible in JPD.
As a workaround, you could take a look at Released Roadmaps, which does enable you to create a JQL filter that only displays items for 2 weeks.
Take a look at this post for how it works.
Caveats:
- Released doesn't support grouping yet.
- The board can not currently be shown in a JPD project. Hopefully future extension points will enable that.
Adrian.Lester
Thanks Jens.
