Hello -
I'm working on setting up JPD to collect and synthesize customer feedback. I like the concept of being able to merge the tickets together, but when I do that, I'm realizing I can't add up totals of merged tickets into the main ticket.
For example: Using GMV to prioritize a feature. Each similar idea from a customer has an associated GMV. I'd like to, when I merge ideas, be able to see on the main ticket the total GMV value an idea represents.
Currently this data resides in a custom field, not an insight.
Is there any solution to preserve the total value of fields when tickets are merged?
Hi @peter dassenko -- Welcome to the Atlassian Community!
There is no built-in feature to sum the fields for an Idea merge.
One possible workaround is to use an automation rule, triggered on Issue Linked:
This rule is a bit complicated and needs to use mitigation for possible timing challenges. I recommend experimenting / testing before rolling a rule like this into your production site.
Thank Bill - what you're suggesting seems like what I would need. Unfortunately it's far outside of my area of expertise at the moment to construct that.. Appreciate you pointing me in the right direction!
You may want to chat with your Jira Site Admin for help; they may have more experience with rule-writing and could offer coaching, or perhaps even create the rule for you.
Hi @peter dassenko ,
Not sure if this will help, but you can link the correlated / "child" ideas to the "parent" idea (which I believe would be one of the GMV ideas in your case). Whenever you link ideas to a "parent" idea, they increase the total number within the Linked issues field:
You could then use the Linked issues field in a custom formula (along with other fields) if that is something of interest, since this will sum or total:
