Syncing Polaris custom fields with Software Project
Hannah Garvin
Scenario:
I have created custom fields in a Polaris Project e.g. High time estimate and want to send this value to the 'Original Estimate' field in a Software Project when I create a delivery ticket.
I have reviewed the below-linked article, but as I am no development engineer, I don't understand the examples and what triggers are being used to set up automation.
https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/
I have successfully achieved a similar automation for the Polaris Overview field being transferred to the Jira Software Project Descriptions field.  The key thing here is these fields are standard/preset in their respective project boards, whereas the fields I now want to be automated from Polaris are custom fields to populate preset Software fields (e.g. Story Points and Original Estimate)
How do I use custom code to do this - how do I understand the examples given in the article link to write my own automation when I am no engineer?  Please make this user-friendly as I have had an engineer look at your coding examples and they can't even work out what is triggering what and delivery what.
Rohan Swami
March 22, 2023
Hi Hannah, I've sent you a follow up email.
For those following along in the Community, below is an Automation example for copying Story points from a Discovery Project to Jira Software. Note that the Story Points field is incompatible with Automation so I've created a custom field called Story point estimate JSW.
Jan-Hendrik Spieth
March 23, 2023
@Rohan Swamithe images don't show. Could you check?
Rohan Swami
March 23, 2023
thanks @Jan-Hendrik Spieth i've reuploaded it should work now.
Like Jan-Hendrik Spieth likes this
Shaun Jeavons
hi @Hannah Garvin  - I'm trying to update the other way (i.e. I have an Epic linked to a RDP Idea (implements/implemented by) and can't get it so that when I update my Story Point Estimate field in my Epic that it updates a RDP Idea Story Point Estimate Total (Custom Field).
Do you have a view on how this might work (i.e. would it just be reversing your automation perhaps using the 'Parent' instead of 'linked issues'?)
